Search In
  • More options...
Find results that contain...
Find results in...
Air intake over CPU cooler?
Masters2150
 Share
Take the Meshify C for example, using the Dark rock Pro 4. Would adding 2 140mm intakes in the above fan slots help, hinder, or make no difference?
it can help, but not much.
Model: HP Omen 17 17-an110ca CPU: i7-8750H (0.125V core & cache, 50mV SA undervolt) GPU: GTX 1060 6GB Mobile (+80/+450, 1650MHz~1750MHz 0.78V~0.85V) RAM: 8+8GB DDR4-2400 18-17-17-39 2T Storage: 1TB HP EX920 PCIe x4 M.2 SSD + 1TB Seagate 7200RPM 2.5" HDD (ST1000LM049-2GH172), 128GB Toshiba PCIe x2 M.2 SSD (KBG30ZMV128G) gone cooking externally Monitor: 1080p 126Hz IPS G-sync
Desktop benching:
Thanks.
I seriously see you alot, do you stalk these forumns?!
Hurt & hinder mean the same thing. But that wouldn't happen.
If you use them as intakes it'd help keep a positive pressure. With the Meshify C (and many other popular cases) the front and top grills are filtered and if you keep more air going into the case than being pushed out, that'll keep dust from being sucked into cracks.
From a cooling standpoint, more airflow is always better IMO.
From a noise standpoint, you'll be making more noise for the same amount of airflow if you don't actually need the extra cooling & are using the headers on your PC + fan curves. I love my fan controller for this reason (see my signature)
My rig:
CPU: Ryzen 5 3600 3.6Ghz, OC'ed to 4.2Ghz all core @ 1.325ghz + Corsair H60 120mm AIO
MB: Gigabyte B450 I Aorus Pro WiFi
RAM: G.Skill TridentZ 16GB (2 x 8GB) 3200Mhz 16-18-18-38 XMP enabled
GPU: Gigabyte RTX 2080 Super
*bought for $200 CAD off a friend who needed an RTX 3080, price was my reward.
CASE: InWinn A1 Plus in White with included 600w gold sfx PSU and included custom length cables
DISPLAY: 3x 20" AOC 1080p 60hz 4ms ,  32" RCA 1080p/60 TV mounted above, all on a single arm.
Storage: C : 1TB WD Blue NVMe      D : 2TB Barracuda      E: 240GB Kingston V300 (scratch drive)
NAS: 240GB Kingston A400 + 6x 10+ year old 700GB Barracuda drives in my old FX8350+8GB DDR3 system
Mining Rack: 240GB Kingston A400 + 5x RX 580 8GB + 2x GTX 1070 + 1x GTX 1660ti + 6GB DDR3 + Core2Quad Q6600
Logitech G15 1st Gen + Logitech G602 Wireless
Steam Controller + Wired XB1 controller + Logitech G29 Racing Wheel + Wingman Extreme Digital 3D Flight Stick
Sennheiser HD 4.40 Headphones + Pixel Buds 2 + Logitech Z213 2.1 Speakers
My Girlfriends Weeb-Ass Rig:
Razer Blade Pro 17 2020
10th Gen i7 10875H 8c/16t @5.1ghz
17.3" 1080p 300Hz 100% sRGB, factory calibrated, 6mm bezel
RTX 2070 Max-Q 8GB
512GB generic NVMe
16GB (2x8GB) DDR4 3200Mhz
Wireless-AX201 (802.11a/b/g/n/ac/ax), Bluetooth® 5.1, 2.5Gbit Ethernet
70.5 Whr Battery
Razer Huntsman Quartz, Razer Balistic Quartz, Razer Kraken Quartz Kitty Heaphones
*deep breath*
Razer Raptor 27" monitor, IT'S BEAUTIFUL.
Ya meant help, tired tonight.
2 minutes ago, Masters2150 said:
Thanks.
you can put it that way... it's my browser's home page after all
Desktop benching:
HA that is amazing but not that surprising
PC: CPU: i5-9600k - CPU Cooler: be quiet! Dark Rock Pro 4 - GPU: Sapphire Radeon RX 5700 XT 8GB GDDR6 - Motherboard: ASRock - Z370 Extreme4 - RAM: Team - T-Force Delta RGB 16 GB DDR4-3000 - PSU: Corsair - TXM Gold 550 W 80+ Gold Certified Semi-Modular ATX Power Supply - Case: Thermaltake - Core G21 TG
Anyways, what about this scenario:
Meshify C with 2x140 intake on front, 240 AIO in the roof with intake, and 120 exhaust. Still positive airflow, but how well would it work ya think?
I see the aio getting getting fresh air fron the top, GPU gets fresh air from the front, and it all exhausts out the back or any other gap.
You will gather dust on top of your case faster since dust will settle down by gravity and you help them to settled there easier even you have filter on it.
But this is a review of how to setup intake fans which involving top fan mounts to get the most of cooling performance of a case
https://www.gamersnexus.net/hwreviews/2301-most-comprehensive-corsair-400c-benchmark-review-specs/Page-2
My system specs:
CPU: Intel Core i7-8700K, 5GHz Delidded LM || CPU Cooler: Noctua NH-C14S w/ NF-A15 & NF-A14 Chromax fans in push-pull cofiguration || Motherboard: MSI Z370i Gaming Pro Carbon AC || RAM: Corsair Vengeance LPX DDR4 2x8Gb 2666 || GPU: EVGA GTX 1060 6Gb FTW2+ DT || Storage: Samsung 860 Evo M.2 SATA SSD 250Gb, 2x 2.5" HDDs 1Tb & 500Gb || ODD: 9mm Slim DVD RW || PSU: Corsair SF600 80+ Platinum || Case: Cougar QBX + 1x Noctua NF-R8 front intake + 2x Noctua NF-F12 iPPC top exhaust + Cougar stock 92mm DC fan rear exhaust || Monitor: ASUS VG248QE || Keyboard: Ducky One 2 Mini Cherry MX Red || Mouse: Logitech G703 || Audio: Corsair HS70 Wireless || Other: XBox One S Controler
My build logs:
That's how I thought at first, until I realized how little space Fractal gave for a top mounted radiator. Push pull or thick rads won't work up there as it blocks the toip of the motherbaord.
Desktop benching:
Well ram at 40mm or below will work. It does exist: https://ca.pcpartpicker.com/product/LbCD4D/crucial-ballistix-tactical-tracer-16gb-2-x-8gb-ddr4-3000-memory-blt2k8g4d30bet4k
8 minutes ago, Masters2150 said:
not just RAM, but also VRM heatsink and even the EPS power plug.
Desktop benching:
Hmm didn;t think of that, how do you find out the height of those components?
i dont know about the VRM heatsink height, but on the power connector side, just make sure the connector is near the corner of the board, not at the middle like the EVGA X299 Micro2
Desktop benching:
Was looking at gigabyte boards, most of them are.
Looks like they fit a 240 in the top It's using an Asus prime board, but it looks like thers plenty of room for higher vram.
 Share
