Search In
  • More options...
Find results that contain...
Find results in...
Razer Mic not working but picks up output sounds
Francis27
 Share
My Razer headset v1 was working fine then suddenly the microphone is not working, but the speaker is working fine. I tried messing up with the driver and settings but I notice that the microphone could be faulty since it is also not working on my iPhone 6s, it has 3.5mm with the microphone so it should work on my phone. I opened my headset and check the wires, but everything still intact and the wires are good also the jack looks sturdy and not broken. So I'm just wondering if what could cause this issue, I can replace the jack, but if can someone can point what could be the issue that would be very helpful! Thank you so much in advance!
 Share
