Search In
  • More options...
Find results that contain...
Find results in...
temps are low, usage is low -> frames not good still
stamparts
 Share
So I have this nice 240 refresh rate monitor. I got a high-end rig to play overwatch at this framerate, what I hope will be a little bit higher, even. Instead, Overwatch frames are 140-200 with ALL SETTINGS SET TO LOW @ 1080p, so that's wierd. I check msi afterburner (photo attached).
rig: gtx 1070 ti & a very, very overclocked i7 4770k.
hmmm. So there's nothing that should be throttling and my game is on all-low settings with a framerate max at 300fps... BUT my pc won't work harder despite usage and temperatures being reasonably low. What on earth is going on here?msiaft.thumb.png.2870100dc60d24fbee0aafa3430b934b.png
note: overwatch allows a maximum framerate of 300, which is what I'm trying to shoot for but my system won't get there
What happens when you go to 'Ultra' settings. Have you downloaded the latest graphics drivers, also if you just purchased that GPU did you use DDU before installing the latest Nvidia drivers?
AMD Motherboard Tier List  GPU Cooling Tier List  PSU Tier List  A Dive Into Custom Keyboards & Mechanical Switches
NEWCOMERS Remember to ' Reply ' to comments in order for people to see them, this is done by clicking the arrow icon at the bottom of a comment (Quote).
My Builds:
MEGA Desk Build
Blueberry Pi  R9 3950X  Asus X470 ROG Crosshair VII Hero Wi-Fi ATX  Corsair Vengeance RGB Pro 4x16GB 3200MHz CL16  EVGA GTX 1080Ti SC Black Edition 11GB  EVGA P2 850W w/ Blue Sleeved Cables  Cryorig R1 Universal (Blue)  2x Corsair Force MP510 4TB w/ Asus Hyper m.2 V2  Corsair ML Pro Blue LED Fans  Fractal Design Meshify C TG ATX Mid Tower
Asus ROG SWIFT PG348Q 100Hz IPS G-Sync UW  Dell UltraSharp U3419W 60Hz IPS UW  Custom TOFU96  Corsair Scimitar Pro RGB
Work Rig  ThreadRipper 3970X  Asus Prime TRX40 Pro ATX  G.Skill RipjawsV 8x32GB 3200Mhz CL16  Nvidia Quadro RTX 6000 24GB  Corsair HXi 1000W  EVGA CLC 360 AIO  8x Sabrent Rocket 2TB w/ 2x Asus Hyper m.2 V2   Arctic P12 Fans  Phanteks P400A ATX Mid Tower
Plotting Machine 1  ThreadRipper 2990WX  AsRock X399 Taichi ATX  Kingston HyperX Fury 8x16GB 2666Mhz CL18   Nvidia Quadro K600 1GB  Corsair RMx 850W  EVGA CLC 360 AIO ‖ 2x Sabrent Rocket 2TB & 2x Sabrent Rocket 4TB w/ Asus Hyper m.2 V2  Arctic P12 Fans  Rosewill RSV-L4500 4U  5x Dell DS60 60-bay JBOD w/ 1.2PB of HDD Storage  HP 22U Half Rack
Plotting Machine 2  R9 3950X  Asus TUF X570-Plus Wi-Fi ATX  G.Skill RipjawsV 4x16GB 3200Mhz CL16   Nvidia Quadro K600 1GB  Corsair RM 650W  Noctua NH-D15s Chormax ‖ 4x Corsair MP600 Force 1TB W/ Asus Hyper m.2 Gen4  Arctic P14 & P12 Fans  Silverstone FARA R1 ATX Mid Tower
J.A.R.V.I.S.  R9 3900XT  Asus B550-I ROG STRIX Wi-Fi ITX  G.Skill Ripjaws V 2x16GB 3600MHz CL16  EVGA GTX 1080 SC2 iCX 8GB  Corsair SF 750W Platinum  Corsair H100i Pro AIO  Noctua NF-A12x15 Chromax Fans  FormD T1 SFF ITX Case
LG 75UM8070PUA 4K UHD 120Hz IPS HDR TV  Corsair K63 Cherry MX Red Special Edition Wireless  Corsair Ironclaw RGB Wireless
Archive Server  R3 2200G  Asus B450-I ROG STRIX Wi-Fi ITX  Corsair Vengeance RGB Pro 2x8GB 3200MHz CL16 White  Vega Integrated Graphics  EVGA P2 750W  Prism Wraith Cooler  ITX Open Bench  2x HP SAS Expander  LSI-SAS9211  220TB of HDD Storage
SFF ITX Home PC  i5-7500  MSI B250I Gaming Pro Wi-Fi AC ITX  G.Skill Ripjaws V 2x8GB 2800MHz  Intel Integrated Graphics  Seasonic SSP Flex ATX 300W PSU  Cryorig C7  Velka 3 rev 1.2 SFF ITX Case (Grey)
Laptop  Dell XPS13 2-in-1 7390 (2020)  i7-1065G7  32GB 3733MHz LPDDR4x  Intel Integrated Graphics  1TB NVME M.2  UHD+ (3840 x 2400) InfinityEdge Touch Display
Keyboard Collection  GMMK Full Size  TOFU96 90%  ‖ KBD8x MKII TKL ‖ Drop CTRL High Profile TKL ‖ KBD Bella 75% ‖ GMMK Pro 75% ‖ XD84 Pro 75%  KBD67 V2 MKII 65%  KBD67Lite 65%  TOFU65 65%  KBD Blade 60%  Drop Carina 60%  Southpaw75 60% w/ Left Numpad  OLKB Preonic V3 Ortholinear ‖ CosPad XD24  ‖ KBDPad MKII
Key Cap Collection  GMK Boba Fett  GMK Red Samurai  GMK Laser CyberDeck +Novalties  GMK Arch  MaxKey B&W  Drop MT3 Camillo ‖ Matt3o MT3 /dev/tty  KBDfans Biip Torii Ext-2048  ePBT Less But Better +Novalties  EnjoyPBT Dolch  WinMix Mustard  Drop Skylight Horizon & Slate ‖ Glorious Black Aura
Mechanical Key Switch Collection  Zealios V2 65g  Zealios V2 78g ‖ Zilents V2 67g  Tealios V2 67g  C³ Kiwi ‖ C³ Tangerine  Invyr Holy Panda  Durock T1 67g  Kailh Box Thick Jades ‖ Kailh Box Royal ‖ Kailh Box Heavy Dark Yellow ‖ Kailh Box Heavy Burnt Orange  Kailh Box White  Kailh Box Red  Kailh Pro Purple  Kailh Pro Burgandy  Gateron Ink Black V2  Gateron Black  Gateron Yellow  Gateron Brown  Gateron Green  Gateron Blue ‖ Cherry MX Black ‖ Cherry MX Brown ‖ Cherry MX Red
I just used DDU before clean installing drivers right before I decided to make a post. I reinstalled the drivers with only the graphics drivers, no geforce experience or sound drivers. I also tried installing it with geforce experience and that didn't work either. My framerate is pretty much the same on ultra setting, funny enough.
That's weird cause those numbers at Ultra seem normal, couldn't tell you why your 'Low' settings performance is that far off though.
My Builds:
MEGA Desk Build
Is your Power management mode in your Nvidia control panel(Global) set to Prefer maximum performance?
Is your Power management mode in your Nvidia control panel(Overwatch.exe) set to Prefer maximum performance?
Are your frames limited/capped in your in game settings and/or your MSI Afterburner?
frames limited in game to 300, msi afterburner no cap set. yes to both nvidia settings
Change this to display based and see what it does.
I tried that too, no change in fps
I'm going to completely reset my PC and install graphics drivers MSI afterburner and OverWatch only - see what happens
You may not get a change in fps. You're looking to see if this changes your GPU usage.
Most likely the same results will happen. Unless you haven't updated to the driver that was released yesterday yet. That may help but I would keep your expectation low. Drivers most of the time seem like the first thing to change but from my experience, the driver you've always been using is usually just fine. In fact, I think I have updated my driver twice in two years. Been using the same one for probably a good year now. It's performed so well for me, no reason to update it.
This is what I would pay attention to in Overwatch. I don't own the game but I hear all the time from multiple people that the more CPU usage you get in Overwatch, the less GPU usage you will be getting.
Well, I upgraded my gpu recently - I'll see what happens and get back with screenshots of afterburner on low and high settings and with display-based/300 cap too.
There's the answer right there. You might could try reseating your GPU if nothing else helps. Then update to the latest driver for that GPU.
well, you see the thing is I reset my pc after I switched out the GPU's so it shouldn't really be a problem.
 I uploaded some more screenshots at either display-based or 300 mixed with low or ultra settings.
order: ultra/display based -> low/300 -> low/display-based -> ultra/300
so it looks like the gpu is not pushing itself that hard if it's hitting 200 fps on low settings, but will go to 100% on ultra to try to get to 200fps.
I just posted msi afterburner pics for ultra settings
All of this seems completely normal. What are you trying to accomplish? More than 200 fps right?
I'm trying to get consistently at least 240
Try this, put all your settings on low/off except for texture quality. Put texture quality on high. No limit on your fps. I think it's custom then 300. Vsync off, triple buffering off, reduce buffering off. Graphics quality should say EPIC but under advanced, put everything on low/off except for texture quality. Put it at high.
Play for like 5-15 minutes(maybe one round) on the Oasis map. Check your fps in both the before game lobby(where everyone is waiting together to go out and kill) and check your fps when you get to the other side and do all the killing(this area).
Your GPU and CPU shouldn't be doing much usage(around 50-70% usage for both), this is normal. No need to screenshot any MSI AB usages. Just tell me the fps you are getting in both these areas on average. Between ??? and ??? in the before game lobby and between ??? and ??? in the killing area on other side of map.
So before the match begins (ie there's no fighting/killing happening and we're all waiting in spawn) my frames are capped out at 300. Once the fighting starts it drops to 180-220.
This is almost completely normal with a 1070 ti in Overwatch. I say almost because there are things you can do with your PC to get better performance in games. You should be able to go from 180-220 to 205-245(seeing mostly around 225) with the settings you just used. How to accomplish this is optimizing your PC itself by things like disabling background processes, disabling dozens of things in Windows 10 settings(if you have W10 that is), disabling in-game overlays(in all the clients you use).
In a game like Overwatch, your fps will vary in certain areas of the game itself. Just as you saw you were at 300 fps in the lobby. It's like this with the majority of games that have an open world for you to explore. Like I said though, optimize your PC in ways you may not have done yet to gain an extra boost in performance.
There's also overclocking your 1070 ti.
So my gpu is the bottleneck?
 Share
