Search In
  • More options...
Find results that contain...
Find results in...
how to connect 4 monitors
Lucky Gill
 Share
So i have a desktop with an i5 4440 processor.
I would like to connect 5 monitors. Not sure what kind of graphics card would i need. Its only for stock investing so i will not need anything too crazy.
AND, do you think there will be more graphics card on sale for black friday or Cyber monday?
If you can please help, that would be awesome.
Thank you.
Just get a couple of basic graphic cards, gtx 1050's. Do not run them in SLI mode. Most of the 1050's I have seen are pretty cheap and have three video outputs.
https://www.newegg.ca/Product/ProductList.aspx?Submit=ENE&IsNodeId=1&N=100007708 601306821 601306822
you can sort on newegg by the # of monitors supported. heres a link
i7-8700k @ 4.8Ghz | EVGA CLC 280mm | Aorus Z370 Gaming 5 | 16GB G-Skill DDR4-3000 C15 | EVGA RTX 2080 | Corsair RM650x | NZXT S340 Elite | Zowie XL2730
no reason to get 1050's for this job
1030 is even a bit overkill for 2d graphs
the only reason to get a 1050 would be if you wanted all 4 monitors to be connected to the same gpu
Well, he said 5 monitors in the post, otherwise I'd have said the 1030's.
 Share
