1060 6GB OC Help
Solved by Jurrunio,
Just now, eWizard said:I wanna get around 130-144 frames out of it for Rainbow Six Siege while still having decent looking graphics
You will gain at best 10%, so I hope you're already getting 120fps.
1 minute ago, eWizard said:Can I start raising the voltage and frequency until I don't see any more gains or until my system becomes unstable without damaging the card?
Yes, but no need to touch the voltage slider. It doesnt raise the maximum voltage your GPU will receive anyway.
2 minutes ago, eWizard said:I imagine it's not a terrible cooler.
it's overkill
