Search In
  • More options...
Find results that contain...
Find results in...
Visual difference of MSI cards
Daddy Dave
 Share
 So I am thinking about buying a used MSI 1080 TI GPU. I cannot tell the difference between the 1070 MS I cannot tell the difference between the cards MSI cards they make.  Does this car look like it is a 1080 Ti I do not want to get scammed
1070 only has 8 pin power, nothing below a 1080Ti takes dual 8 pin.
I/O is consistent with what a Pascal card would have.
Worth noting that the 1080Ti is one of the hardest cards to fake. Even with a different vBIOS and everything, it's pretty hard to make a 1080Ti scam card that actually works as a scam.
If my post solved your problem/answered your question, please consider marking it as "solved"
Community Standards // PSU Tier List // Bugs and Issues // Join Floatplane! // Join the LTT Official Discord //
The 1070 twin frozr had 8+6 pcie power . This has 8+8 , it's the real deal. Plus , that cooler would be awfully thick for a 1070
AMD Ryzen 7 3.8ghz at 1.3V Corsair vengeance LPX 8GB 2800mhz @ 3200mhz CAS 16 + 2*4GB micron ballistics @ 3200mhz cas 16 ;Gigabyte ga-ab350-Gaming 3; cooler master nepton 240M ; CF r9 290x tri x + r9 290 tri x ; CX750M PSU ; SPEC 03 case with 9 120mm fans ; windows 10 64 bit
Ok so I’m not getting scammed ?
if anything, worry about if the card works or not.
Model: HP Omen 17 17-an110ca CPU: i7-8750H (0.125V core & cache, 50mV SA undervolt) GPU: GTX 1060 6GB Mobile (+80/+450, 1650MHz~1750MHz 0.78V~0.85V) RAM: 8+8GB DDR4-2400 18-17-17-39 2T Storage: 1TB HP EX920 PCIe x4 M.2 SSD + 1TB Seagate 7200RPM 2.5" HDD (ST1000LM049-2GH172), 128GB Toshiba PCIe x2 M.2 SSD (KBG30ZMV128G) gone cooking externally Monitor: 1080p 126Hz IPS G-sync
Desktop benching:
How can I check that
you can;t. That's the gamble of going used.
Desktop benching:
Hey shoot. If it doesn’t work can I tell pay pal
I dont think they can help you on that.
Desktop benching:
Ideally you'd want the seller to show it working when you go pick it up. If it's ebay, you might be able to file a complaint/refund request
Take a test bench with you.
hes not local
1 hour ago, Daddy Dave said:
hes not local
If you buy through eBay or amazon, use PayPal and you have double protection you're guaranteed to get your money back if needed
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 2 VR
How do I get double protection
i mean if the card doesnt work you can fill a claim to ebay or amazon...this is your first protection they will guide you through a refund process and just in case they argue with you or something (which they pretty much never do BTW) then you can contact Paypal and tell them ebay or amazon is fucking with you...and they will make sure you get your refund.
oh yeah you are right.
Do you know about used parts ?
yes it,s safe to buy used PC parts especially something like a graphics card that came out not too long ago like a 1080ti...MSI cards are top notch and the seller wouldn't put it on ebay or amazon if it wasn't in good working condition...if the price is good and it's worth it to you then i would buy it...
Personally i buy my graphics cards used all the time but i buy them locally because the market around montreal is big and it's easy to find good deals and i hate to wait for shipping ?
 I know that the price right now for a 1080 TI used is like 500$ but what are the prices for something like a ROG Strix ( the motherboard I want ) or the CPU I want.
 Share
