High Vcore Stock values on ryzen. Please Help
Solved by Turtle Rig,
What are your temps at this 1.4v it puts it on ? Your CPU is not going to die that easy, so don't worry about that. It goes to TJ max and shuts down to save its life. You should be able to do 3.8Ghz without barely touching the vcore. Yes 1.4v is not cool, no phun. Try to restore the BIOS everything to defaults and go to aida and check your vcore. Step by step well fix you up man.
