What is a good usb hub
TMobile
Hey, I'm looking into getting a usb hub, to clean up my cables. What should I look into? What are so respectable brands?
I'll use it to connect my k70 lux, corsair sabre and void. So it needs at least 4 usb ports. Do I then need one with extra power? And would it be better to have one with a usb-c cable?
Thanks in advance!
If you're formally an engineer, avoid responsibility. That's what senior engineers get paid for.
USB 3.0 or 2.0?
Primary PC:
2 minutes ago, fasauceome said:
USB 3.0 or 2.0?
3.0, preferably
