Ryzen 1600x + AiO vs Ryzen 2600 + Stock
Marko96
My question is simple. What is a better option. Ryzen 5 1600x + AiO cooler or Ryzen 5 2600 + Stock cooler? The reason I'm asking is because im building my first PC right now. My budget is stretched too much already, and I literally cannot afford 30$ more. Basically, what i buy now is what i get, and I'm not upgrading it any time soon. So what should i choose? 1600x can perform as or even ourperform 2600 when OC, and i cannot OC if i have stock cooler on 2600 and as i said, im not going to buy anything else any time soon.
I'm more for 1600x and AiO, because it simply looks much better :D and RGB does add some FPS to my gaming.
I'd like to see what does my community think about this :D
My complete build will be:
1 minute ago, Marko96 said:
snip
you can do better, even for the more little budget you want to spend. what is your exact budget?
Can you please make a PCPartPicker list?
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
It's hard to say, since I'm not from the US, prices are too inflated here in Serbia
Which exact PSU and AIO are you planning on buying?
I've dealed with sebian pricing before. what about that I use german pricing and you look it up yourself on local shops?
So my question is. Should i got like this. Or change 1600x to 2600 with stock cooler. 1600X is 40$ cheaper than 2600, adding a AiO will get me 10-15$ more expansive than 2600. And I'm not planning to upgrade stock cooler to AiO if i get 2600
Ryzen 5 2600 with stock cooler... don't get AiO... it's a gimmick...
Personal Desktop":
Luna, the temporary Desktop:
I have both air and water cooling. An AIO is a good solution and better than air cooling. The OP should go with air and 2600 though.
Ryzen 5600 Be Quiet! PureBase500DX  CoolerMaster MasterLiquid 240mm RGB  Asus ROG Strix B450-F  1660 Super  Crucial DDR4 32GB 2x16 3800mhz  SK Hynix Gold P31 1TB NVMe  Seagate Barracuda 3TB  Mechanical Keyboard Red switches Logitech G502 mouse  EVGA Supernova 750w GA gold   32" Acer curved 1440p 144hz  MSI 32" Curved 1440p165hz  Aopen 32" 1440p 144hz
