Search In
  • More options...
Find results that contain...
Find results in...
Extended Mousepad Recommendations to Replace Goliathus Speed
 Share
Hi everyone! I've learned a lot from this forum over time, and it's finally come time to replace my own mousepad. Up to this point I've thoroughly enjoyed using my old, medium-sized Razer Goliathus Speed (Link).
I am now looking for an extended mat - one that is around 90x4 cm. Unfortunately the Goliathus Speed extended is only around 90x30cm, and I want one that's taller.
Which of the below (or others) would you recommend if I wanted something with as close as possible smooth material to the Goliathus Speed?
  • Cooler Master Swift-RX XL (Link)
  • Cooler Master MP510 XL (Link)
  • Asus ROG Scabbard (Link)
  • Steelseries QcK Heavy XXL (Link)
  • Thermaltake Dasher Extended (Link)
  • Redragon P006 (Link)
Thanks in advance for your suggestions :)
Check out Linus' video on mouse pads, his guide explains which mouse pads have the most control/speed.
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
Thanks. That was a good video. I also watched these reviews: http://www.rocketjumpninja.com/mouse-pad-reviews.
I've heard good things about Glorius pads, but they're unfortunately not available in my country.
I've decided to go with the Swift-RX, as it apparently feels very much the same, and has the same speed, as the Goliathus Speed pads.
 Share
