What is the difference between a Thunderbolt 3 active and passive cable?
Solved by r2724r16,
Passive cables can deliver 40Gbps at 0.5m and 20Gbps at up to 2m. Active cables can deliver the full 40Gbps up to the 2m limit.
You'll need an active cable if your thunderbolt cable is more than 0.5m long.
HelloFriend ·
Posted in Troubleshooting1 -
TurleyV16 ·
Posted in Troubleshooting3 -
Rumman ·
poly ·
Posted in General Discussion4 -
7
skayqz ·
Posted in Graphics Cards3 -
11
3
bat_verified ·
Posted in New Builds and Planning13
play_circle_filled
Latest From Linus Tech Tips:
He Spent 3 YEARS Begging me for a PC. Good Luck Finding it!
