Soundboard Hiss How to fix?
Solved by ShredBird,
Some things to try are:
- Get a filtered AC power plug.
- Try a different circuit from computers and other noise generating equipment.
- OR try different combos of plugs (could be a ground loop issue).
- Get a ground lifter for your interfaces and/or power:
- Use a noise gate if possible.
- Use the smallest amount of gain you can get away with.
