Search In
  • More options...
Find results that contain...
Find results in...
Vesa mount for 100x200
Dreamzlol
 Share
I'm getting a new monitor for xmas which has a standard 75x75 or 100x100 vesa mount. I want to put it on a dual arm with my existing 24" however it has a 100x200 mount. How would I go by doing this.
Would I be able to mount this bracket to the monitor and then the monitor arm into the bracket ?
https://www.officeworks.com.au/shop/officeworks/p/brateck-23-42-display-wall-bracket-201c-anbtlc201c
 Share
