Need Cherry MX Silent Red advice
Solved by geo3,
17 minutes ago, ChestyTech said:okay, well I found this Filco at $169 https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=3900 ,is it really worth the extra $, I am not a keyboard elitist, I just want a quality quiet keyboard to last me years. Also, do you have either?
No. I'm exclusively using customs now. However people in the enthusiast community regard Filco as some of the best off the shelf keyboards. Ducky too. Coolermaster keyboards are basically rebranded Filcos so you might want to check them out as well. However if you're not that particular I'd lean towards the Ducky.
