dell optiplex 390 Dell Optiplex 390 upgrade help
1 hour ago, nikobutros said:Hi, I have a Dell Optiplex 390 and would like to upgrade it. I'm thinking of putting an i5 2500k and 8GB of DDR3 memory. Maybe an SSD. But I need help, what PSU would fit and what would be a good budget GPU that can play most games at medium to high? Also one of the front USB ports are physically broken, is there a way to replace it?
Don't bother with an unlocked processor, you will not be able to utilize it. Definitely get an SSD. I recommend a 1050ti.
CPU
SSD
https://pcpartpicker.com/product/sNc48d/samsung-860-evo-250gb-25-solid-state-drive-mz-76e250bam
GPU
https://pcpartpicker.com/product/8fx9TW/gigabyte-geforce-gtx-1050-ti-4gb-video-card-gv-n105td5-4gd
RAM
https://pcpartpicker.com/product/PkQypg/corsair-memory-cmv8gx3m2a1333c9
You can get a USB card to throw into the rig too if you have space which you should.
Don't worry about the PSU.
