so i have a fx 9590. tips on cooling for long term use.
so i was reading about the amd fx 9590. then i also read it melts motherboards so i naturally had to buy it. now i have tested this thing and it does run hot as expected. my concern is the motherboard heat from what i like to call the hot spot on my motherboard. im open to ideas on a full custom water cooling set up and case modification. any input would be greatly helpful.
thanks all!!!
970a gaming pro carbon with the bios update for 220watt
corsair vengeance pro 2x8 2133hmz
corsair vengeance pro 2x4 1600mhz
msi 1060 6gb gaming x
thermal take 240 water cooling rgb water 3.0
other parts
msi 990fxa g65
modified antec h20 650 water cooler
