Will I be able to create partition of storeMI
Solved by Electronics Wizardy,
1 minute ago, user73 said:Really?
I'm bit outdated so plz advice.
If i have 500gb of data on Cdrive e.g videos for adobe premier,will i be able to backup OS excluding that 500gb of that data?and when restoring OS that 500gb data remains untouched?
Normally you do file and image backups, so you can restore a old version of the os, then restore the files.
This really depends on what goes wrong, you can also just restore the windows files that have the problem.
But really if your editing video id just get a ssd, it will be much faster than the tiered solution. Id just get a single 1tb ssd here, and some hdds for old projects and backups.
