Search In
  • More options...
Find results that contain...
Find results in...
Why is some 3200 memory cheaper than 3000 memory?
Go to solution Solved by Shimejii,
Availability, Stock, and Just what is currently in bulk.
I noticed that with several models of different memory that are the same module except for the speed, 3200 and 3000
why is that?....shouldn't faster memory be more expensive?
(yes i'm aware this question is probably stupid and/or unimportant)
ah....ok...yeah..my question was pretty stupid..
the best example is a set of ddr3000 cl14 b-die 2x16gb i saw on newegg, that kit will naturally cost more than a kit of ddr3200 hynix cl16, other than that, brand supply matters if all else equal.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll evga non-3090 tie ftw3 1905 0.8v 65C 270w (double fps of 1080ti) ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll all nf12/14 fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll x27 ll PA272w
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666  bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA non-30 tie XC 1830//7600 0.85v 210w ll  8x nf12/14 fans 2x samsung 860 evo 500gb raid 0 ll 500gb nvme 970 evo ll Corsair graphite 780T ll EVGA P2 1200w ll Windows 10 Pro ll NEC PA242w (movie, work mon dying) 1080p 60hzll Predator X27 4k144 hdr (using at 4:4:4 98 fan is dying)
Different Dies or differently binned dies mostly
 Share
