What will performance be with a FX-6300 (@4.2ghz) and GTX 1070?
Solved by Wh0_Am_1,
8 minutes ago, pigsforever said:Hi, I know that the FX-6300 will severely bottleneck the GTX 1070, but I was wondering what performance would be like if I got the 1070. If it helps, I mainly play Fortnite. I also plan to upgrade my CPU to a Ryzen 5 2600 sometime soon. Thank you!
System:
FX-6300 (@4.2ghz)
12GB (one stick is dead) of DDR3 Ram
GA-78LMT motherboard
1 TB hard drive
TXM 550w PSU
~60-70 FPS max settings at FHD.
