Search In
  • More options...
Find results that contain...
Find results in...
Input lag on a wired, bluetooth-able device?
DrThots
 Share
I was planning on buying a non-display tablet for drawing and testing it out for OSU, I came across the Wacom Intuos Medium With Bluetooth which can be connected using either cable or bluetooth. There is a non-bluetooth version of it as well for cheaper (but only in small version).
My question is, If I turn off the bluetooth and play it wired (medium version) will there be any increased input lag than playing it wired without having bluetooth on the device at all (small version) ?
 Share
