Search In
  • More options...
Find results that contain...
Find results in...
CPU video card and monitor
Im working on my first build and have got alot of help today on all the components I want to use. The only thing im unsure about is if my CPU video card and monitor are all going to work well together. I keep hearing about builds having a bottle neck. I also cant decide if a 1080 ti or just 1080 is worth buying based on the build. I dont plan on trying to run 4k on every game nor do I plan on buying a monitor that is as costly as the computer itself.
MSI - Optix G27C2 27.0" 1920x1080 144Hz Monitor
AMD - Ryzen 7 2700X 3.7GHz 8-Core Processor
Gigabyte - GeForce GTX 1080 Ti 11GB Gaming OC 11G Video Card
It will work just fine
Model: HP Omen 17 17-an110ca CPU: i7-8750H (0.125V core & cache, 50mV SA undervolt) GPU: GTX 1060 6GB Mobile (+80/+450, 1650MHz~1750MHz 0.78V~0.85V) RAM: 8+8GB DDR4-2400 18-17-17-39 2T Storage: 1TB HP EX920 PCIe x4 M.2 SSD + 1TB Seagate 7200RPM 2.5" HDD (ST1000LM049-2GH172), 128GB Toshiba PCIe x2 M.2 SSD (KBG30ZMV128G) gone cooking externally Monitor: 1080p 126Hz IPS G-sync
Desktop benching:
I know bottlenecking is unavoidable to a degree but I am wondering if the monitor will be able to keep up with the cpu and video card or should I look into a different monitor with higher resolution.
There certainly are games that need this kind of hardware to hit 1080p 144fps with ultra graphics settings
Desktop benching:
 Share
