i7 4790K or i5 7600K? Help me choose
Solved by Fasauceome,
1 minute ago, SGM said:Now the question is: should I sell it or should I buy some DDR4 RAM and replace my old system with it?
I would only consider it a good upgrade if you got an i7 7700k (or 6700k). Otherwise, you're better off with good old haswell, since four cores get choked a lot lately in new titles.
2 minutes ago, SGM said:I'd possibly need a new CPU cooler too if my H100i isn't compatible with LGA 1151 (haven't checked).
LGA 1150 and 1151 have identical mounting.
2 minutes ago, SGM said:8 cores total as opposed to the 7600K's 4.
Not quite. a hyperthread =/= a core, it's not nearly as good.
