Posted October 30, 2018 I can't decide.... I have pretty much exactly $850 to spend [+tax] Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 30, 2018 3 minutes ago, RANDEAG said: $100 DisplayPort to DVI Adapter Unless it also washes dishes then never pay 100$ for that... Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 30, 2018 3 minutes ago, RANDEAG said: I can't decide.... I have pretty much exactly $850 to spend [+tax] Need more context in order to help you friend. It would depend on what you need. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 30, 2018 $100 adapter o_O Ryzen 5 1600 @ 3.9 Ghz | Gigabyte AB350M Gaming 3 | PaliT GTX 1050Ti | 8gb Kingston HyperX Fury @ 2933 Mhz | Corsair CX550m | 1 TB WD Blue HDD Inside some old case I found lying around. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 30, 2018 Author 2 minutes ago, Kiyometa said: Need more context in order to help you friend. It would depend on what you need. I need a 2070, but I also wanted to delid my cpu. Basically just wanted to see what other people would choose given the options. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 30, 2018 1 minute ago, RANDEAG said: I need a 2070, but I also wanted to delid my cpu. Basically just wanted to see what other people would choose given the options. Well both of the options you have listed has a 2070. So then which is better for you? Do you need the extra speed that would result from delidding your CPU, or would the Monitor be better? Is it a quality of life thing? Do you need another monitor for productivity or is it just extra? What GPU do you have right now? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 30, 2018 Delidding and liquid metal is like a few degrees, really monitor is a much better way to spend your money IMO. Really you might as well just get a 2080 unless you want another monitor. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 30, 2018 Author 1 minute ago, Kiyometa said: Well both of the options you have listed has a 2070. So then which is better for you? Do you need the extra speed that would result from delidding your CPU, or would the Monitor be better? Is it a quality of life thing? Do you need another monitor for productivity or is it just extra? What GPU do you have right now? lol if I knew what was better, i wouldn't be askin! I don't need the extra speed, just wanted to maximize my benchmarks. The monitor would be almost wasteful since I already have a 144Hz monitor, and would have an extra 144Hz that I wouldn't be using. I guess I could try to sell my old one though. It's much more quality of life than necessity, besides the video card. That upgrade is a must. Using a 750 ti atm. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 30, 2018 19 minutes ago, RANDEAG said: I can't decide.... I have pretty much exactly $850 to spend [+tax] So uhh... the 2070 has hdmi. HDMI to DVI-D is like a 5-15 dollar cable max, and foolproof. Displayport to DVI is a mess, requiring an active cable and lots of other messy things. So do option 1, but buy an hdmi to dvi-d cable instead. https://www.amazon.com/AmazonBasics-HDMI-Output-Adapter-Cable/dp/B014I8UL8U/ref=asc_df_B014I8UL8U/?tag=hyprod-20&linkCode=df0&hvadid=167141218295&hvpos=1o1&hvnetw=g&hvrand=10740739950991302506&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9018721&hvtargid=pla-187910164619&psc=1 LINK-> Kurald Galain: The Night Eternal Top 5820k, 980ti SLI Build in the World* CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC // Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB Mass SSD: Crucial M500 960GB // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15" LINK-> Ainulindale: Music of the Ainur Prosumer DYI FreeNAS CPU: Xeon E3-1231v3 // Cooling: Noctua L9x65 // Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333 HDDs: 4x HGST Deskstar NAS 3TB // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 30, 2018 (edited) Just get a better GPU then like a 2080. You can get a pretty cheap 2nd monitor which is a nice quality of life thing. I have a cheap $100 24" monitor as 2nd monitor. I'm not an crazy overclocker so I think unless you are competing or the CPU is slowing you down in your productivity that delidding is not worth it. Delidding just to get better benchmark scores is silly. Edited October 30, 2018 by Kiyometa Added thoughts Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 30, 2018 Author 1 minute ago, Curufinwe_wins said: So uhh... the 2070 has hdmi. HDMI to DVI-D is like a 5-15 dollar cable max, and foolproof. Displayport to DVI is a mess, requiring an active cable and lots of other messy things. So do option 1, but buy an hdmi to dvi-d cable instead. https://www.amazon.com/AmazonBasics-HDMI-Output-Adapter-Cable/dp/B014I8UL8U/ref=asc_df_B014I8UL8U/?tag=hyprod-20&linkCode=df0&hvadid=167141218295&hvpos=1o1&hvnetw=g&hvrand=10740739950991302506&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9018721&hvtargid=pla-187910164619&psc=1 I don't think that supports 144Hz, does it? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 30, 2018 18 minutes ago, RANDEAG said: I can't decide.... I have pretty much exactly $850 to spend [+tax] You can get those adapters for like under $5... Also go for the second monitor with a 2070 you have a better asset that way and you can always make your money back less people will want to buy a cpu thats been messed with. thats the way i would look at it. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 30, 2018 Author 1 minute ago, Tz000 said: You can get those adapters for like under $5... Also go for the second monitor with a 2070 you have a better asset that way and you can always make your money back less people will want to buy a cpu thats been messed with. thats the way i would look at it. Needs to be dual link active adapter for 144hz true about the cpu tho Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 30, 2018 3 minutes ago, RANDEAG said: I don't think that supports 144Hz, does it? Of course it does. HDMI (1.4) and DVI-D are literally pin-interchangable. Anything you can run with 144hz DVI-D you can run with the cable. Heck, if you want to know something really amusing. Most DVI ports on graphics cards in the last 5 years aren't actually DVI. They are HDMI in the DVI form-factor. Thus when you use a DVI to HDMI passive cable, it even carries digital audio via hdmi. LINK-> Kurald Galain: The Night Eternal Top 5820k, 980ti SLI Build in the World* CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC // Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB Mass SSD: Crucial M500 960GB // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15" LINK-> Ainulindale: Music of the Ainur Prosumer DYI FreeNAS CPU: Xeon E3-1231v3 // Cooling: Noctua L9x65 // Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333 HDDs: 4x HGST Deskstar NAS 3TB // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 30, 2018 2 minutes ago, RANDEAG said: Needs to be dual link active adapter for 144hz true about the cpu tho Yes, but it is dual link. It doesn't need to be active. LINK-> Kurald Galain: The Night Eternal Top 5820k, 980ti SLI Build in the World* CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC // Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB Mass SSD: Crucial M500 960GB // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15" LINK-> Ainulindale: Music of the Ainur Prosumer DYI FreeNAS CPU: Xeon E3-1231v3 // Cooling: Noctua L9x65 // Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333 HDDs: 4x HGST Deskstar NAS 3TB // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 30, 2018 Just now, Curufinwe_wins said: Of course it does. HDMI (1.4) and DVI are literally pin-interchangable. Anything you can run with 144hz DVI you can run with the cable. Heck, if you want to know something really amusing. Most DVI ports on graphics cards in the last 5 years aren't actually DVI. They are HDMI in the DVI form-factor. Thus when you use a DVI to HDMI passive cable, it even carries digital audio via hdmi. Well fooled me lol learn something new everyday.. cheers. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 30, 2018 (edited) Just make sure the cable is rated for the requisite throughput to handle 144Hz, AKA if the one end is DVI-D, should be fine. Double check though, I have been bamboozled in the past with those adapters. Edited October 30, 2018 by Kiyometa Added thoughts. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 30, 2018 Author Just now, Curufinwe_wins said: This isn't true. What?! I've been looking at all this for over a week now and have never heard any alternative to it. Is there any sort of verification you have on HDMI supporting 144hz? All I can find are forum posts like this "No. Only DisplayPort can support that. It has been able to support that since 2009.HDMI can only support 120Hz, and even then, only with version 1.4b or 2.0. the following chart shows what each version of HDMI can support, but it seems to show that 1.4a can do 120Hz which I have confirmed several times it cannot support."http://www.tomshardware.com/forum/id-2776527/hdmi-cable-support-1080p-144hz.html Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 30, 2018 1 minute ago, Tz000 said: Well fooled me lol learn something new everyday.. cheers. Yep. I have a HTPC hooked up via 'DVI' on the rear of a measly Radeon 3450 to the TV via HDMI and the digital audio is crucial, since that PC has just crap onboard. LINK-> Kurald Galain: The Night Eternal Top 5820k, 980ti SLI Build in the World* CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC // Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB Mass SSD: Crucial M500 960GB // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15" LINK-> Ainulindale: Music of the Ainur Prosumer DYI FreeNAS CPU: Xeon E3-1231v3 // Cooling: Noctua L9x65 // Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333 HDDs: 4x HGST Deskstar NAS 3TB // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 30, 2018 Author 1 minute ago, Curufinwe_wins said: Yep. I have a HTPC hooked up via 'DVI' on the rear of a measly Radeon 3450 to the TV via HDMI and the digital audio is crucial, since that PC has just crap onboard. Oh, didn't read below the ad in the middle. Thanks for the save. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 1, 2018 Author On 10/30/2018 at 12:20 AM, Curufinwe_wins said: Of course it does. HDMI (1.4) and DVI-D are literally pin-interchangable. Anything you can run with 144hz DVI-D you can run with the cable. Heck, if you want to know something really amusing. Most DVI ports on graphics cards in the last 5 years aren't actually DVI. They are HDMI in the DVI form-factor. Thus when you use a DVI to HDMI passive cable, it even carries digital audio via hdmi. Dude WTF.... Just got the exact cable you linked with my 2080 since I thought I wasn't gonna have to spend 100$ on an adapter, and it won't go past 60Hz.... Crazy how one confident dumbass can make a weeks worth of research go out the door..... I KNEW you were wrong... ..!.. Go fuck yourself Read this or shut your mouth next time the topic is brought uphttp://www.tomshardware.co.uk/forum/id-3675170/connect-120-display-construction.html#_=_ Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 1, 2018 Author On 10/30/2018 at 12:21 AM, Curufinwe_wins said: Yes, but it is dual link. It doesn't need to be active. Fucking moron..... I really wanted to believe it... Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
