Search In
  • More options...
Find results that contain...
Find results in...
Is Asus eeebook E203NA is suitable for arduino programing
Is Asus eeebook E203NA is suitable for arduino programing and using applications like processing3, fritzing. I have a very tight budget the only far I can go  up to Rs 14000 or $200
eebook? arn't those the atom netbooks? Well it would not be fast (that they used java also does not help) but in the end it should run smoothly.
Fritzing is a bit more hardware consuming. Unless you want the images fritzing generates it might be worth to switch to a real EDA.
Go used
My Desktop specs:
AMD Ryzen 5 5600 Nvidia RTX3060Ti 8GB PNY XLR8 Gaming Epic-X RGB 16GB (8X2) 3200MHz CL16 Team Group MP33 Pro 1TB
ID-Cooling SE-224-XT White Gigabyte B550M DS3H mATX Tecware Forge M2 mATX White Case Montech Century 650W Gold
 Share
