After installing RGB LED strip pc won’t boot?
TroymyJam
i just installed an rgb strip into my pc and it won’t boot. it was working perfectly fine before. I just placed the strip and placed a sata power cable into the connector to power it. any solutions?
whenever I hit the power button a red light and blue light turn on on the mobo and the cpu heat sink fans begin to spin, but nothing after that.
Did you remove the strip yet?
Primary PC:
