Search In
  • More options...
Find results that contain...
Find results in...
Z370-F mobo fan header count
 Share
So I'm simply wondering how many 4-pin fans I can connect to this mobo?
If you look at the attached picture, you can see all available fan headers,  and I can see they all have the same 4-pin (PWM, FAN IN, FAN PWR, GND). Can I connect my 4-pin fans to any off these regardless if its the CHA_FAN1, M.2_FAN, CPU_OPT etc?
The label means nothing, they will all power a fan. You may find different levels of control for each header though, which means that certain speed settings will only be available for certain headers.
Primary PC:
i7 8086k (won) - EVGA Z370 Classified K - G.Skill Trident Z RGB - WD SN750 - Jedi Order Titan Xp - Hyper 212 Black (with RGB Riing flair) - EVGA G3 650W - dual booting Windows 10 and Linux - Black and green theme, Razer brainwashed me.
Linux Proliant ML150 G6:
Dual Xeon X5560 - 24GB ECC DDR3 - GTX 750 TI - old Seagate 1.5TB HDD - dark mode Ubuntu (and Win7, cuz why not)
How many watts do I need? Seasonic Focus thread, PSU misconceptions, protections explainedgroup reg is bad
Alright that seems easy enough. Is there a way to check which headers have speed settings?
 Share
