Search In
  • More options...
Find results that contain...
Find results in...
I think my MOBO is killing every Cpu I put in it, What should my Cpu voltages be? (i7 4790)
I had some serious stuttering issues with my system. After upgrading from an i5 4590 they seemingly went away for a while but have raised their head again on games that were working fine the other day.
I want to make sure all of my voltages are completely fine. I have checked HW Monitor, but I don't know what I'm looking for at all.
Is it possible that my Mobo is killing my components and if so would I see these sort of symptoms, or just have outright fails, and shutdowns?
I have attached my HW monitorUntitled.thumb.jpg.062ad17f1e0507c65ec51f6b29042984.jpg
Look in your BIOS to see what the voltage is at.
Quote me to see my reply!
SPECS:
CPU: Xeon X5650 OC'd to 4.2GHz @ 1.35V (courtesy of @XR6)Motherboard: Asus Sabertooth X58 RAM: 6x4GB G.Skill Ripjaws X GPU: Asus RX 570 Strix Storage: 512GB Samsung 850 Pro and 1TB WD Blue PSU: EVGA 600B Case: Fractal Design Define C Cooling: H100i V2, be quiet! Pure Wings 2 (two intake, two exhausting through radiator) Monitor: 3x Dell P2210 on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: It changes, but usually Focus FK-9000 Mousepad: Steelseries QcK XL Headphones:  Sennheiser HD598SE and MEE M6 Pro
"If you don't measure things, it's not engineering; it's art." - Jack Ganssle
VID looks OK, VCore looks OK...
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
Yeah, or if for some reason you dont want to look at aida64
voltages look fine, should be staying at 1.2V or bellow. check the voltages under a varying load, im thinking its Load Line Calibration(LLC) killing your chips or the PSU
I spent $2500 on building my PC and all i do with it is play no games atm & watch anime at 1080p(finally) watch YT and write essays...
Builds:
CPU Vcore 1.080v
CPU VRIN 1.740v
CPU VAXG 0.756v
How would I record a varying load, say using Prime95. Should I record the highest value, what am I looking for?
Also had the stuttering on a previous PSU, so it isn't that. Not even sure if the stuttering is related to CPu, but everything in the PC has been replaced but the Motherboard. I did buy another Mobo and test my i5 4590 on it, but who knows if that was already damaged, since the stuttering existed there to.
id use some render benchmark probably and a game or two. you are really just looking for max voltage and seeing if avrage voltage gets suspicisly high
Builds:
11 minutes ago, Polarisandneptune276 said:
CPU Vcore 1.80v
no wonder
Model: HP Omen 17 17-an110ca CPU: i7-8750H (0.125V core & cache, 50mV SA undervolt) GPU: GTX 1060 6GB Mobile (+80/+450, 1650MHz~1750MHz 0.78V~0.85V) RAM: 8+8GB DDR4-2400 18-17-17-39 2T Storage: 1TB HP EX920 PCIe x4 M.2 SSD + 1TB Seagate 7200RPM 2.5" HDD (ST1000LM049-2GH172), 128GB Toshiba PCIe x2 M.2 SSD (KBG30ZMV128G) gone cooking externally Monitor: 1080p 126Hz IPS G-sync
Desktop benching:
These are my results after running cinebench twice
13 minutes ago, Polarisandneptune276 said:
CPU Vcore 1.80v
missed this, but this is the problem. this shouold be like 1.15-1.2V... 1.4+ degrades and 1.8V would kill a chip pretty quick. set it to auto in the BIOS
Looking at this though it dosent seem like its actiually using that voltage though, as here they are clearly normal.
Builds:
So there doesn't seem to be a problem with the motherboard?
not one that HWINFO picked up on at least. if you havent already id reset the BIOS and flash the latest version too but the motherboard dosent seem to be the one. bad wall power and bad PSUs can also hurt components so those would be next in line to check
Builds:
Already flashed to latest version and toyed with and reset the Bios a lot. Maybe my stuttering is elsewhere. Thanks anyway :)
CPU Vcore 1.080v
CPU VRIN 1.740v
CPU VAXG 0.756v
Seems fine, what are your temps?
SPECS:
I do see highs of up to 75, but mostly under 70 and about 35 idle.
I have 4790 and my temp are like yours. what MB are you using?
Gigabyte H81-s2v
45 minutes ago, Polarisandneptune276 said:
Gigabyte H81-s2v
My z87x oc force survived extreme heat in 2016 ……… I was using a bios version on my motherboard I was using F10 and I am suppose to use F9 because it is the last official stable bios version ….. they only posted F10B but I found the FINAL F10 in forum ……… anyway I was taking a shower which is located next to my room, when I finished and went out I felt extreme heat coming from my room ..... I felt heat from semi far room…… it was my crashed pc ….. no BSOD only black screen and very very loud fan noises ……. I was afraid to go near my pc because it is giving out a lot of heat …… I turn it off from the wall ………. I think is was a graphic card issue …… however I returned both of the titan x pascal 2016 and Nvidia replaced them for me.
if your pc has issues like crashing to black screen then your fans goes really loud you should turn it off when you go out.
I am still using the same ram cpu and mb ... they still work ok.
 Share
