Fx 8350 cooler upgrade?
Tree_tt
Go to solution Solved by WoodenMarker,
8 minutes ago, Tree_tt said:
is the SR slim worth the extra $14 AUD?
Yeah, it's still decently priced.
Hi.
I am currently running a fx 8350 (125 W TDP) with stock cooling, the fan is really loud and i would like better temps. I have my eyes on the Cryorig H7, Be quite pure rock and hyper 212x. My budget is around the $70 AU ($45 US) area and i want a cooler with support for intel 115x and the AMD  AM3+ sockets.
I am hoping someone can help me choose what would be the best cooler or maybe have another suggestion. I live in Australia BTW.
Cheers!
P.s my tower can fit about 150mm high cooler (inwin mana 136) from measuring it just now, i cant find official sizes anywhere but if necessary i am willing to do modifications to the side panel but would rather not.
Any of those coolers will work fine for you, good choices.
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
Oh, sweet.
which one of those would you say is best value for money. the pure rock and 212x are couple dollars apart ($45 and $49 respectively) and the h7 is $65?
i just found that the be quite shadow rock slim is a thing ($59). that seems to be a sort of middle ground?
is that any good?
I couldn't say, haven't used either and they look almost identical from what I can tell.  Probably go with the 212x simply due to having the 212EVO for years and it worked great, no noise and I OC"d my 4670K to 4.4GHz easily.
OnePlus:
Other Tech:
is that any good?
No, it's a lower TDP and is more for small cases that can't fit a full size cooler.  Skip it.
OnePlus:
Other Tech:
are you looking at the shadow rock slim or pure rock slim, because i was referring to the shadow rock slim which doesn't match with what you said (they really need to work on their naming scheme IMO)?
13 minutes ago, Tree_tt said:
Oh, sweet.
Are these Canadian prices? Can't imagine why the 212 is so expensive. I recommend the Be Quiet cooler, since you specified quiet, effective cooling.
Primary PC:
You're right, it popped up the Shadow Rock LP.  Found this in a review comparing Shadow Rock Slim vs Pure Rock..
Either will be good for the job however what is the make and model of your case? The Shadow Rock Slim is 5mm shorter than the Pure Rock cooler. FYI apart from heat dissipation, they will be the same in terms of temps when compared to the Hyper 212X. Only thing is the Be Quiet! cooler will be quieter.
OnePlus:
Other Tech:
AU.
OnePlus:
Other Tech:
inwin mana 136. good luck finding any useful information about it.
which Be quite! are you referring to?
34 minutes ago, Tree_tt said:
Hi.
Cheers!
The Cryorig H7 is an excellent choice, same for the be quiet! Pure Rock. Please do not get a Hyper 212X, the Hyper 212 should not be a consideration in today's market.
Another suggestion I can put forward is the Arctic Freezer 33 eSports One, it's a cooler which should easily fit in your budget, and is a great option for both performance and visuals.
mechanical keyboard switches aficionado & hi-fi audio enthusiast
switch reviews  how i lube mx-style keyboard switches
can i ask why the 212x is worse? curiosity reasons.
The pure rock
Certainly not at that price, but they're still discoverable here and there at $25 USD this was the appeal to begin with.
Primary PC:
Poor build quality, cheap materials, difficult installation, less quiet fans
Primary PC:
There are much better options at a little more cost. It's poorly-built, has the most bare-bone construction, it's difficult to install, it looks like a $5 cooler, and was made over half a decade ago, it's not a good choice anymore.
They are awful to install tbh. It's one of the reasons why if you can i would go with a similar performing cooler from a diffrent brand.
fair enough, i cant argue with that.
Australian -- so like America's Canada's Canada.
It supports coolers up to 176mm without side panel fans or 156mm with standard 25mm thick fans. https://www.nikktech.com/main/articles/pc-hardware/pc-cases/79-in-win-mana-136-midi-tower?showall=&start=5
I still prefer the 212x installation over the H7.
is that any good?
Asides from ease of installation, the SR Slim is better than every other cooler mentioned so far.
so the pure rock is the best value then, and will handle the 8350 fairly well?
The Pure Rock is plenty if you're not planning to oc much or at all and is very quiet. If you do want to oc, the Ninja 4 seems to be not much more than the SR Slim and performs substantially better: https://au.pcpartpicker.com/product/RZfmP6/scythe-cpu-cooler-scnj4000
Can I get confirmation on the shipping price listed for the Ninja 4 from Amazon? It's listing $22.51 but I'm not sure if that's because I'm in the US.
Ninja 4 cost is pretty high shipped, and i can't find any retailers that sell it here either, besides Ebay but thats about the same or more.
i do want to do a little OC because the IPC of the FX chips is a not great.
