Search In
  • More options...
Find results that contain...
Find results in...
Looking for Cooler for my Ryzen 2600
CrazySnake96
 Share
Hi guys i'm new here and i am having heat issues with my ARTIC freezer 13 CO when running games with my Ryzen 5 2600, i noticed when gaming even with the fan on the cooler at max when set to max in BIOS i still get over 80 Degrees C, i really need a new cooler that will fit my ASUS Prime A320M-K motherboard (crap i know dont judge) i'm looking at getting this (see attached) if you guys can give me pointers and tips it would be great.
Thanks for the help
Snake
Be Quiet Dark Rock TF CPU Cooler - Black_ Amazon.co.uk_ Computers & Accessories.html
I suspect a bad cooler install or thermal paste application instead. The Arctic Freezer 13 CO cooler is more than capable of handling the 2600.
Model: HP Omen 17 17-an110ca CPU: i7-8750H (0.125V core & cache, 50mV SA undervolt) GPU: GTX 1060 6GB Mobile (+80/+450, 1650MHz~1750MHz 0.78V~0.85V) RAM: 8+8GB DDR4-2400 18-17-17-39 2T Storage: 1TB HP EX920 PCIe x4 M.2 SSD + 1TB Seagate 7200RPM 2.5" HDD (ST1000LM049-2GH172), 128GB Toshiba PCIe x2 M.2 SSD (KBG30ZMV128G) gone cooking externally Monitor: 1080p 126Hz IPS G-sync
Desktop benching:
3 minutes ago, CrazySnake96 said:
Budget/Country?
Probably just get a Hyper T4, Cryorig H5/H7, Arctic Freezer 33
How'd you end up with a 92mm cooler? it wasn't going to be much better than the stock cooler.
Trying hard with that mobo, but try a new thermal paste applyance and dont screw the cooler in too hard, you can short some pins with that
or maybe bad airflow...
@CrazySnake96
What case you using?
My Folding Stats - Join the fight against COVID-19 with FOLDING! - If someone has helped you out on the forum don't forget to give them a reaction to say thank you!
The only true wisdom is in knowing you know nothing. - Socrates
Please put as much effort into your question as you expect me to put into answering it.
  • CPU
    Ryzen 7 1700 3GHz 8-Core Processor @ 4Ghz
  • Motherboard
    GA-AX370-GAMING 5
  • RAM
    DOMINATOR Platinum 16GB (2 x 8GB) @ 3400mhz
  • GPU
    Aorus GTX 1080 Waterforce
  • Case
    Cooler Master - MasterCase H500P
  • Storage
    Western Digital Black 250GB, Seagate BarraCuda 1TB x2
  • PSU
    EVGA Supernova 1000w
  • Display(s)
    BenQ - XL2430(144hz), Dell 24" portrait
  • Cooling
    MasterLiquid Lite 240
budget is anything up to £100 and UK, and i work in hardware and at the time the freezer 13 was all i could afford
£100 budget ..dude grab urself a Noctua NH-D15 . its pritty much the best aircooler u can get and can beat or match 240mm AIO's
CCL has it atm for about £80.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
 Share
