Need an air cooler for my Ryzen 1700x
Kaputau
Hi just like the tittle says i need to pick a cooler for my ryzen. Im torn  apart by my choices(  "be quiet! CPU cooler Dark Rock 4"  "Arctic Freezer 33 eSport Edition" "Arctic Freezer 33 Plus, CPU cooler" ).Weill they be enough to cool it You can offer anything or just give advice on the ones I listed. :)
I'd go bequiet as they are German (:P) and are regarded one of the best cooler brands out there right now.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
2 minutes ago, Kaputau said:
Will it keep the ryzen cool ?
Yeah it should keep the cpu cool and allow for good overclocking headroom. Bequite and nactua are regarded as the best cpu air cooler brands on the market. They both make top quality coolers.
Nice, i dont really plan to overclock it much but thx for the advice :)
If you're not planning to oc much, any of them will do. Why are you looking at these coolers in particular?
I need a cooler asap and the vendor only has these and some other in stock, other would take up to 2 weeks to get if I order  them but i need my pc to uhm... survive.
The DR4 is the best performer and the quietest. The Freezer 33 eSports Edition is very similar to the 33 Plus but comes with better fans and a longer warranty.
Any of them will do. Make sure that there's enough clearance in your case for whichever you go for.
I just picked up a Dark Rock 4 cooler and was very impressed with the build, performance, and included fans.  If that's one of your choices I'd recommend it.
Bonus: you get a screwdriver  :)
"And I'll be damned if I let myself trip from a lesser man's ledge"
