Is there any negative to buying a bigger power supply than you need
Solved by Fasauceome,
9 minutes ago, Wisconsin gamer said:If I don’t fill out the wattage as much though will it really cause issues. I mean it should be running at about 500 right away but then as I tweak overclocking etc it will get to 650-700.
I just don’t want to have issues like it won’t cause any major malfunction by having it not utilize more of the power.
if you're running at 50% load it's fine
