freezing Games freeze but sound keeps going on?
Solved by Cereal5,
Your computer won’t shut down if it’s a RAM or CPU issue. What games do you play? It’s likely a RAM issue, since windows does all its start up stuff, that uses some RAM. Once all that is done it likely drops RAM usage a bit. 8GB is starting to become not enough. And yes, in CPU-Z and other programs, RAM will show up at half speed, because DDR stands for double data rate
