How to attach own fan to cryorig c7
Solved by DailyProcrastinator,
47 minutes ago, PingPonguin said:He told me that it almost reaches 80 degrees Celsius when he streams Rainbow 6 Siege for a couple of hours, and that the fan is loud. I also noticed that the Intel stock cooler makes a ticking noise/machine gun noise when it spins at high RPM.
Then a fan swap should help, I'd suggest using zip ties though that would work best.
Intel stock coolers are crap so I'm not surprised, the fan bearing is probably failing.
