Monitoring PS4/XboxOne temperatures/throttling?
Solved by Mira Yurizaki,
Changing the thermal compound may reduce the temperature by a few degrees, but it likely won't be enough to make the fan curve go to a lower setting.
Otherwise, I don't see a point in monitoring the temperatures since you can't really configure the thermal or performance profiles in consoles.
Los_Jackal ·
Posted in Storage Devices1 -
TurboTrym ·
Pepegovich ·
Posted in Troubleshooting0 -
4
Crystalized King ·
Posted in Graphics Cards2 -
6
Fluuwu ·
Posted in CPUs, Motherboards, and Memory4 -
2
14
