Search In
  • More options...
Find results that contain...
Find results in...
Broadband modem vs Router speed problems...
lcfz1986
 Share
Im using 4G to running my internet speed... so i test using broadband modem (can use to travel) and router...
Broadband modem = Huawei E5577
Router = Asus RT-AC1200G+ with D-Link DWM-222
Broadband modem speed test is 40mbps...
but router speed test is only 15mbps...
my router i default setup and no blocking any website or any complicated setting...
is the router got any setting is blocking my internet speed?
So weird...
Are you using 2 routers to extend range? Or just one at a time?.
If you are using it as range extenders,it is expected.I have two routers at my house,one is wired and second one is used as range extender.I Get 50MBps from first one and around 18-23 from the second one.I read it somewhere when i was researching this that second router(extender) will only give you 1/2 or lower than the main one.
In your case,Huawei is directly connected to internet,It 'll give you the most/best speed than the other ones which(I presume) you use redistribute or extend the internet.
its due to the limitation on the D-Link DWM-222.
The Huawei E5577  has better built in wireless card and cpu,
With the Router = Asus RT-AC1200G+ with D-Link DWM-222 its double natted and the performance on the d-link is less than Huawei.
 Share
