5.1 using aux
Reece565
So, I bought a set of logitech z906
But I didn't realise that I couldn't use all 5 speakers and the sub through a aux on my phone to play spotify music, it only plays in 2.1
I want to have the music play on all 5 speakers and the sub, can I buy a amp that will do this, so just the 3.5 from the speakers to the amp and then a 3.5 from the amp to the phone, thanks
Use 3.5mm splitters so you can plug the phone into all 3 jacks instead of just the green one.
Image result for logitech z906
If you can hook a PC up that has the 6 I/o 3.5 on the mobo, then its going to make the channels separate.
I don't think splitting it out a phone is going to work because most (if not all) have L/R and mic, so still going to give the 2.1 instead of the desired 5.1
You could just put the rear satellites next to the front satellites and call it a day?
I make intelligent lights do cool things
Spotify isn't going to output 5.1 regardless of what you do, a splitter will get the music to all the speakers.
Main PC: Corsair 900D | ProArt Z690-Creator | Intel 13900K | RTX 4090 | Trident Z5 (2x32GB) | 1TB 980 Pro, 2TB Sabrent Rocket 4+, 2TB 980 Pro, 1TB Sabrent Rocket | HX1200i
Capture PC: Meshify XL | Designare TRX40 | AMD 3960X | 2xRTX 4070 TI | Trident Z (4x16GB) | 2TB 970 Evo Plus, 1TB 970 Evo Plus | Dual HDMI 4K Plus LT, 2xElgato 4K 60 Pro, HX850
Media / Render PC: Corsair 900D (shared) | ASRock X399M | AMD 2970WX | RTX 4070 TI | Trident Z (2x16GB) | 2TB Samsung 970 Evo | 2xElgato HD60 Pro | HX750
Full Room Watercooling: EK X3 400 | EK-XTOP Revo Dual D5 | 4xHardware Labs 560GTX | 16xSilentWings 4 Pro  | EVGA 450 B3
Peripherals: Logitech G502 X |  Wooting 60HE | Xbox Elite Controller Series 2 | Logitech G502 Wireless | Logitech MX Keys Mechanical
Displays: Asus XG35VQ | 2xLG 24UD58-B | LG 65UH6030 | Asus VH242H | BenQ GW2480 | HP 22CWA | Kenowa CNC-1080P | Asus VC39H
Audio Interfaces : RME Fireface UFX+, Scarlett 18i20, RME HDSPe RayDAT, RME HDSPe MADI FX, RME ADI-648, RME ADI-192 DD
Audio Playback: 2xYamaha HS5 & Yamaha HS8s | Sennheiser HD820, Sennheiser IE 500 Pro, Ultimate Ears RR CIEMs
Don't those speakers have the matrix mode button or whatever that already does that internally?
#Muricaparrotgang
