Search In
  • More options...
Find results that contain...
Find results in...
System interrupts clogging Ryzen 1700x when using OBS Studio or SLOBS
Hi all,
I'm am at a loss to try and figure out what is going on with my PC at the moment so maybe someone can help me out.
What I am finding is the moment I open either OBS Studio or Streamlabs OBS my entire pc starts stuttering and freezing. No matter what I tried and the only way to make it stop was to shut down either programme. I found out through research that if I opened task manager, I would see that 'system interrupts' would start using upwards of 15% of my Ryzen 1700x CPU. I have no clue on how to try and narrow down what's causing this to happen and how I go about fixing. Now I have installed a new SSD and a pcie usb 3.0 hub but I don't know if this has caused the issue. I did run elgato game capture as I have a cam link attachedd to the hub and my hd60 which are used when I open OBS and I could not replicate the problem. Please be gentle as I know a bit but trying to problem solve is not my strong point!
Please someone help!??
Edited by mustybruce
Spelling error
 Share
