Help Needed with Lost Power Supply AC Adapter
Solved by jonnyGURU,
6 hours ago, Boomwebsearch said:Yes, I have a PSU cord which looks very similar to the one in the image which you have included. Does anyone happen to know what type of cord this is although (so that I can ask for buying it in a store)? I have ones like this one although they are dedicated for other systems, so I would need to have more than the number of systems I have and run regularly.
It's called a PC power cord.
https://www.amazon.com/s/ref=nb_sb_noss_2?url=search-alias%3Daps&field-keywords=PC+power+cord
