Search In
  • More options...
Find results that contain...
Find results in...
What graphics card should I go for 144hz 1440p G-sync monitor?
Okay, so I have never build a computer before and this would be my first time, usually this would bee overkill for a first build, but I'm looking to keep this PC for over 5 years with minimum upgrades. I have spent the past month or two picking out some parts with a budget of $1,000-$1,300 including a monitor. I have parts picked out but I'm stuck on with GPU I should get.
For the CPU is a Ryzen 5 2600x and I got 16gb of ram. The monitor I would be using is a Dell S2417DG which supports G-Sync.
I want to use this computer to stream games and get ABOVE 60fps while streaming. I also want to record game-play and use it for YouTube. I will mainly be playing games like cs:go, fortnite (maybe), and R6. Not too many games and I plan on getting a lot more in the future, maybe GTA 5, Battlefield, or stuff like that. When I'm playing these games WITHOUT streaming I'm looking to get hopefully over 100fps and I might turn some settings down such as shadows, other than that I don't wanna change too much.  I know the monitor has G-Sync so tearing won't really be a problem.
I also edit videos using Sony Vegas and After Effects, I don't know if the CPU will support that entirely but let me know if that doesn't.
I was thinking that a 1070ti would get me to my expectations, I don't want to spend too much money on this. I'm also not looking to overclock ANY of my parts, but if I much to reach these goals then please let me know. If you wanna let a take a closer look at my parts here's a list https://pcpartpicker.com/user/GlucoseGarbage/saved/fXfV6h let me know if I need to change anything so I could have good fps and not be held back when doing any of the things I plan on doing.
Thanks for all the help in advance :D
4 minutes ago, GlucoseGarbage said:
Vegas...and After Effects?
Do you already have the monitor? If not you should probably be buying a 1440p 144hz IPS free-sync display instead.
I'd personally go for a 1070Ti, 1080, or 1080Ti. All of those can be easily found for low prices on the used market.
If my post solved your problem/answered your question, please consider marking it as "solved"
Community Standards // PSU Tier List // Bugs and Issues // Join Floatplane! // Join the LTT Official Discord //
1. do you need wifi?
2. 24" is so small, I dont think you'll differentiate 1080p and 1440p. Better get a bigger monitor since 1080p ones are at best VA panels, which are still a bit short in colour and viewing angles compared to IPS (the dell here is also VA, so I'd use something from a different series).
Model: HP Omen 17 17-an110ca CPU: i7-8750H (0.125V core & cache, 50mV SA undervolt) GPU: GTX 1060 6GB Mobile (+80/+450, 1650MHz~1750MHz 0.78V~0.85V) RAM: 8+8GB DDR4-2400 18-17-17-39 2T Storage: 1TB HP EX920 PCIe x4 M.2 SSD + 1TB Seagate 7200RPM 2.5" HDD (ST1000LM049-2GH172), 128GB Toshiba PCIe x2 M.2 SSD (KBG30ZMV128G) gone cooking externally Monitor: 1080p 126Hz IPS G-sync
Desktop benching:
Get a 27" version first. Thank me later.
And the best GPU is 1080 Ti for this and a decent CPU for course!
I also use the Dell S2417DG and it is a great choice for a monitor. I wouldn't say that you won't EVER have issues with tearing but that depends on which GPU you get. That being said, I use an 8GB GTX 1080 in my rig and I'm very happy with the results (I run two 1080p monitors in addition to the 1440p one). I would say if you are looking at a 1070 Ti, spring for the 1080 (I was able to get mine for $370 on Amazon) or a 1080 Ti if you can find one in your budget. You can squeeze more performance out of it for not that much more money (depending on where you shop). And with cryptocurrency mining starting to fall out of fashion, cards are starting to get cheaper!
Streaming and video editing are going to depend both on your CPU and your GPU. The GPU will help encode actual video but your CPU is doing most of the actual number crunching. The 6 cores on your Ryzen 5 ought to do a good enough job.
39 minutes ago, GlucoseGarbage said:
1080 ti used or 2080 new minimum imho
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll evga non-3090 tie ftw3 1905 0.8v 65C 270w (double fps of 1080ti) ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll all nf12/14 fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll x27 ll PA272w
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666  bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA non-30 tie XC 1830//7600 0.85v 210w ll  8x nf12/14 fans 2x samsung 860 evo 500gb raid 0 ll 500gb nvme 970 evo ll Corsair graphite 780T ll EVGA P2 1200w ll Windows 10 Pro ll NEC PA242w (movie, work mon dying) 1080p 60hzll Predator X27 4k144 hdr (using at 4:4:4 98 fan is dying)
Vegas and AE are both primarily CPU/RAM dependent software. Exporting/Encoding will be a lot happier with a better CPU. So depending on you how you're going to balance the over use of the system, I would get the best CPU you can with that budget. For an extra $100 USD you can get the 2700X and have a lot more headroom for multitasking and your AE/Vegas will out put faster.
If you can get a solid price on a used GPU you can make up the extra money there. If not, I would drop down to 1080p. Having recently made the jump from 1080p 144hz to 1440p 144hz, I was surprised at how much of a dip my FPS took on a 1070TI without dropping game settings.
imo a 1080ti will be perfect. I have a gtx 1080 and the asus pg248q(180hz 1080p monitor). At 1440p a gtx 1080 feels lacking for high refresh rates, you're better off with more frames with a 1080ti. I also have a 4k hdr10 monitor the lg 32ud99, so i know what it is like...
That isn't exactly true. It depends on what games you play and how long you spend to tweak the games. I have a 1080 FE and I run the majority of my games between 120-150fps on a 1440p 144hz monitor. If you're able to fine-tweak your games to boost your fps over the threshold.
I used to use a 4k monitor that died before it and I was still able to achieve 55-60fps on the majority of the games I played just tweaking settings down and still playing with way better visuals than I had at 1080p / than I do sometimes at 1440p.
Do you think overclocking the CPU would work well for editing?
As for the GPU, I kinda want to go used for a 1080 or a 1080ti if I can't find one in my budget. Should I overclock the GPU as well or just risk buying used parts?
I don't the monitor already. Why should I go with Free-sync, I don't think my card is AMD
Free-sync can get you into a 144hz monitor for a lot less than getting a Gsync panel. If you have an Nvidia card and want to minimize tearing turn on Vsync and you should be good. You just lose the dynamic frame adjustments that Free/Gsync give you.
Even if you get an nvidia GPU the free-sync display will be cheaper for the same panel type, if you're in the US anyways at least.
But Vega 56 is back to it's MSRP and is comparable to the 1070ti/1080 depending on OC/undervolt
PCPartPicker part list: https://pcpartpicker.com/list/vxW2xG
Price breakdown by merchant: https://pcpartpicker.com/list/vxW2xG/by_merchant/
Video Card: PowerColor - Radeon RX VEGA 56 8GB Red Dragon Video Card  ($399.99 @ Newegg)
Monitor: Nixeus - NX-EDG27S 27.0" 2560x1440 144Hz Monitor  ($409.99 @ Amazon)
Total: $809.98
Generated by PCPartPicker 2018-10-19 13:29 EDT-0400
RTX 2070 maybe? Regardless of its Raytracing.
In my country MSI RTX 2070 Armor price is same with most of GTX 1080. While GTX 1080 is being quiet old card, and GTX 1070 Ti is perfect for high FPS 1080p gaming and not so high FPS at 1440p. RTX 2070 is perfect for high FPS 1440p, it performs between GTX 1080 and 1080 Ti based on some review I've seen.. While GTX 1080 Ti is still more expensive than RTX 2070, and RTX 2070 is more futureproof.
I don't bother thinking to get GTX 1080/Ti or even RTX ones if I only use a 1080p 144Hz monitor, unless there is an RTX card which specialized at 1080p 120+ Hz display with reasonable price.
My system specs:
CPU: Intel Core i7-8700K, 5GHz Delidded LM || CPU Cooler: Noctua NH-C14S w/ NF-A15 & NF-A14 Chromax fans in push-pull cofiguration || Motherboard: MSI Z370i Gaming Pro Carbon AC || RAM: Corsair Vengeance LPX DDR4 2x8Gb 2666 || GPU: EVGA GTX 1060 6Gb FTW2+ DT || Storage: Samsung 860 Evo M.2 SATA SSD 250Gb, 2x 2.5" HDDs 1Tb & 500Gb || ODD: 9mm Slim DVD RW || PSU: Corsair SF600 80+ Platinum || Case: Cougar QBX + 1x Noctua NF-R8 front intake + 2x Noctua NF-F12 iPPC top exhaust + Cougar stock 92mm DC fan rear exhaust || Monitor: ASUS VG248QE || Keyboard: Ducky One 2 Mini Cherry MX Red || Mouse: Logitech G703 || Audio: Corsair HS70 Wireless || Other: XBox One S Controler
My build logs:
Yeah forgot to mention you can tweak your graphics for extra frames if you don't really care about the looks.
I have $100 and this seems to be a great deal for $50. I want to use things like photoshop and after effects. Will this run these things? Is 2120 any good?
 Share
