Power levels on cat6 cable with no POE
Solved by Swilky,
Do you mean power in watts or voltage as they are two different things...
if you mean voltage it is 2.5v
https://en.wikipedia.org/wiki/Ethernet_physical_layer
Power in watts would be voltage * amps, I do not think there is much current flow as sensing circuitry would be high impedance so the power in watts would be extremely low, tens of milliamps or less.
