Search In
  • More options...
Find results that contain...
Find results in...
Gaming X Trio 2080 fan problem
So I just built a new system with a MSI Gaming X Trio RTX2080 and I noticed that during Time Spy Extreme benchmark, my gpu will ramp up and do its job, doesn’t drop clocks, but the fan on the left of the card (closest fan to the video outputs) does not spin, the other two do just fine but that left fan never spins, is this a problem? Or does that fan only kick in as extra cooling when the card gets to a certain temp. And also, does anybody know if there is a way to control the fan curve on this card? Because afterburner won’t let me.
you have to check a box in Afterburner before you can set up your own fan curve
Model: HP Omen 17 17-an110ca CPU: i7-8750H (0.125V core & cache, 50mV SA undervolt) GPU: GTX 1060 6GB Mobile (+80/+450, 1650MHz~1750MHz 0.78V~0.85V) RAM: 8+8GB DDR4-2400 18-17-17-39 2T Storage: 1TB HP EX920 PCIe x4 M.2 SSD + 1TB Seagate 7200RPM 2.5" HDD (ST1000LM049-2GH172), 128GB Toshiba PCIe x2 M.2 SSD (KBG30ZMV128G) gone cooking externally Monitor: 1080p 126Hz IPS G-sync
Desktop benching:
 Share
