Help with 1440p monitor
martward
Hi all,
So I've been looking for a new monitor for a while now with little success. So I want to upgrade from a 1080p, 60Hz IPS monitor (Dell U2414H) to 1440p and preferably also a higher refresh rate.
I have found the Samsung C27JG50 and the Acer VG270U, but I can't find any proper reviews about them.
My budget is around 350 in The Netherlands, although I would theoretically be able to go up a bit if it's really worth it (or just wait until Christmas deals and such).
I mainly use the monitor for watching Netflix and Youtube, browsing the internet and gaming (Witcher type games, CS:GO a bit, Rocket League).
Do you guys have any monitors you would suggest with a 1440p panel?
Does anyone have any experience with the monitors I mentioned?
Thank you :)
PSU tier list // Motherboard tier list // Community Standards
My System:
AMD Ryzen 5 3600, Gigabyte RTX 3060TI Gaming OC ProFractal Design Meshify C TG, 2x8GB G.Skill Ripjaws V 3200MHz, MSI B450 Gaming Plus MaxSamsung 850 EVO 512GB, 2TB WD BlueCorsair RM850x, LG 27GL83A-B
I have both the Asus PB278Q and PG 278Q (60Hz and 144Hz respectively), and I love them both. Adjustable stand, quality panels, etc etc. The extra refresh rate will cost you some more. You can look at your local used listings to see if there are any deals there, I bought both my monitors used and have had no problems with either. I also don't know popular online retailers for the netherlands, how your import taxes are so...
My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q
Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti
[Under Construction]
My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed
My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s
The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB
R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one.
I can't find the PG278Q here, only the PG279Q which costs about 750 and the PG278QR which is 165Hz and 580. I'll see if I can find one used somewhere. Thanks for the suggestion :).
My System:
