CPU Features and Motherboard
Solved by Guest,
4 minutes ago, Hi P said:Taking Ryzen for example and the StoreMI feature on the 2000 series.
1.- Is that feature only available on B450 / X470? or B350 / X370 too?
2.- Are there CPU features that are Motherboard dependant?
Thank you
1. No, you can't. But amd says you can use third party software, AMD site says: "If you have a socket AM4 motherboard with a 300-series chipset, you can still enjoy the benefits of storage acceleration with Enmotus FuzeDrive software, exclusively for AMD, for an additional fee."
2. Not every MB supports SLI, and not every motherboard has on-board Display ports for use with APU's.(If you want an APU) That's about everything I think.
