Search In
  • More options...
Find results that contain...
Find results in...
Making a sacrifice in performance ? Need help plz
Mugenjynn
 Share
So I have a 1070 ti. I can either get a ryzen 3 2200g and get a 144hz monitor along with that or I can get a better cpu but a worse monitor a ryzen 5 2600 with a 75hz monitor. Which one should I do !?!?!
11 minutes ago, OnyxArmos said:
I would personally go with the Ryzen 5 2600 and just get a good, solid, 1080p 60hz G-Sync IPS 27inch monitor
1080p 60hz is way too low for a 1070ti. 1050ti would be more appropriate for that.
For 1070ti i would go either 1440p 60hz or 1080p 144hz.
I only see your reply if you @ me.
1 minute ago, OnyxArmos said:
Not for playing games at max settings - especially games like Final Fantasy XV
A 1070ti can place all games at max setting right now
Just now, OnyxArmos said:
The thing is, if he gets the worse CPU then he's going to bottleneck his graphics card AND be trying to get 144fps out of it, which I'm pretty sure isn't going to happen in games like Final Fantasy XV and Battlefield
Battlefield is suprisingly not hard to run
 Share
