Search In
  • More options...
Find results that contain...
Find results in...
Does Omen 880 gtx 1070 work in other systems
Itsuhiro
 Share
I'm upgrading from a 970 to a 1070, but the deal I found is for a card that came in an omen 880-149, is there any way that HP would have made the cards not work in any other system but theirs? Just wanna make sure before I buy.
3 minutes ago, Itsuhiro said:
I'm upgrading from a 970 to a 1070, but the deal I found is for a card that came in an omen 880-449, is there any way that HP would have made the cards not work in any other system but theirs? Just wanna make sure before I buy.
HP doesn't make cards, they just install them into the slot, power them on and use them.
Whats the full name of the card...it should have a Manufacturers name followed by GTX 1070.
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Ryzen Rig 3: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler in push/pull, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.  Lenovo 27" 1080p 60hz placeholder monitor, generic mouse, generic keyboard.  Still a work in progress
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Ryzen Rig 2: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) 3600mhz V-Color Skywalker (or 4x8gb DDR4 2666mhz for large tasks), Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.  Zalman K600S keyboard, Zalman ZM-GM1 mouse, Viotek GN24C 24" 1080p 144hz curved and Hannspree HF207 as 2nd monitor
https://www.3dmark.com/3dm/37004594?
Ryzen Rig 1: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire R9 Fury Tri-X Nitro 4gb HBM, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case.  Zalman K600S keyboard, Zalman ZM-GM1 mouse, Acer XF270HU 2560x1440 144hz IPS monitor
https://www.3dmark.com/3dm/37628874?
Unless it has a proprietary auxiliary power cable no. I would assume they use your standard pcie power cable.
Watching the video on https://support.hp.com/us-en/document/c05553403, it looks like they're pretty standard graphics cards so I'm sure it'll work.
Specs: CPU: AMD Ryzen R7 3700X @4.4Ghz, GPU: Gigabyte RX 5700 XT, RAM: 32 GB (2x 8GB Trident Z Royal + 2x 8GB TForce Vulkan Z) @3000Mhz, Motherboard: ASRock B550m Steel Legend, Storage: 1x WD Black 1Tb NVMe (boot) + 1x Samsung 860 QVO 1Tb SSD (storage), Case: Thermaltake Core V21, Cooler: Noctua NH-D15
It should work just fine, I believe in the past i have seen that Omen systems use MSI blower style cooler cards with some different stickers and a green PCB.
Of course that is just one example, but that is just to give you an idea, they don't change the GPU's in the terms of connectors and such
Upon further inspection, I am very confused what that person is trying to sell me, that specific model of omen 880 does not have an installed gpu and the gpu has no clear label of what it is
I found the model and it seems it is actually a card manufactured by HP, and it seems like it is a gtx 1070
model 680-1g411-0020-hp
Send a link to the ebay/craigslist/whatever? May be a fake.
import shittyTechAdvice as RollTime
 Share
