Search In
  • More options...
Find results that contain...
Find results in...
GTX 1070 and Monitor
 Share
Go to solution Solved by r2724r16,
Just now, Chikorita said:
Right now just playing.
  • Overwatch
  • Warframe
Then you may be able to get 165 FPS at 1440p (if you turn down the settings a bit).
Hi, Quick question.
Will my GTX 1070 able to handle a 2560 x 1440 WQHD 165Hz Monitor or is this a bottle neck for it?
Monitor I want to buy : Acer Predator XB271HUbmiprz 27 Inch WQHD Gaming Monitor, (IPS Panel, G-Sync, 165 Hz (OC), 4 ms, ZeroFrame, DP, HDMI, USB Hub, Height Adjustable Stand) Black/Red
Graphics Card : Asus GTX 1070
What games are you playing and at what settings? I personally wouldn't get anything less than a GTX 1080 for high refresh rate 1440p gaming.
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
  • Overwatch
  • Warframe
I usually use Ge Force Experience to auto optimize game settings for me.
5 minutes ago, That_Dutch_Guy said:
Depends, if you crank all the settings than a 1440p 165Hz monitor is definately overkill.
https://www.eurogamer.net/articles/digitalfoundry-2018-10-03-nvidia-geforce-gtx-1070-benchmarks-7001
hmm by the looks of those graphs, I suppose I'll have to save up to get a 1080.. doh
  • Overwatch
  • Warframe
Alright, I'll play around with the settings then. Thanks
  • 2 years later...
On 10/10/2018 at 6:25 AM, Chikorita said:
Hi, Quick question.
update in 2021, no idea if anything has changed since 2018, but I've been running an i7-6700 + gtx 1070 recording setup since 2016, just got an asus 165hz 2560x1440 monitor and it plays every game from BeamNG to Apex Legends at a near locked framerate of 165 on high+ settings.
 Share
