Will I have enough PCIe lanes for a raid 0 upgrade?
Solved by SpaceGhostC2C,
8 hours ago, A-Furry-Peanut said:Sorry I meant the chipset (H97M Pro4) on my mobo, according to the spec sheet on Asrock's site it has "1 PCIe 3.0 x16, 1 PCIe 2.0 x16, 2 PCI"
https://www.asrock.com/mb/Intel/H97M Pro4/
The second (2.0) slot runs in x4 mode. Moreover, if you RTFM, it states that a two-graphics card setup will run in x16-x4 mode, not x8-x8, meaning only the first slot is wired to the CPU directly, using all 16 lanes. The second (PCIe 2.0, xx4 mode) slot is therefore routed through the chipset, just like the PCI (non-e) slots and possibly other things.
