Monitor and framerate
Hiro Hamada
If I buy a 60Hz monitor and play mafia 3 on it with a gtx 1070ti card, will I get more than 60fps on it? My friend has a 60Hz monitor and he is saying the fps varies from game to game and its all more than 60fps in his 60hz monitor
Is that true?
Is that true?
It depends on the rest of your system and in-game settings.
Main system: Ryzen 7 7800X3D / Asus ROG Strix B650E / G.Skill Trident Z5 NEO 32GB 6000Mhz / Powercolor RX 7900 XTX Red Devil/ EVGA 750W GQ / NZXT H5 Flow
Is that true?
Your system can produce more than 60 FPS, but the monitor will physically be unable to display more than 60 FPS as it is capped due to it being 60Hz. Essentially it can be looked at as "wasted performance", though that is good as it gives you sort of a buffer when the frames dip as things get crazy on screen.
Without that buffer, it is more likely you'll notice/ perceive the significant drop in frame rate as things get hairy.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 17.2.1) | iPhone XR (iOS 17.2.1) | iPad Mini (iOS 9.3.5) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
 Explanation, he talks about the difference in frame rates and refresh rates at the beginning
PC: CPU: i5-9600k - CPU Cooler: be quiet! Dark Rock Pro 4 - GPU: Sapphire Radeon RX 5700 XT 8GB GDDR6 - Motherboard: ASRock - Z370 Extreme4 - RAM: Team - T-Force Delta RGB 16 GB DDR4-3000 - PSU: Corsair - TXM Gold 550 W 80+ Gold Certified Semi-Modular ATX Power Supply - Case: Thermaltake - Core G21 TG
