small form factor cooling for i5 7600k
Solved by WoodenMarker,
The C7 should be fine if you set core voltage manually and not aiming for much of an oc.
GOATWD ·
Posted in Peripherals0 -
1
AdamWarlock ·
Posted in Laptops and Pre-Built Systems5 -
Eamonc26 ·
Posted in New Builds and Planning3 -
1
WaitforAmpere? ·
Posted in Audio2 -
Benb112 ·
Posted in Troubleshooting6 -
LukeCorbishley ·
Posted in CPUs, Motherboards, and Memory41 -
pandaarts ·
Posted in Console Gaming7
play_circle_filled
Latest From ShortCircuit:
If you can only get one computer, get this one. - ASUS ROG G14 (2024)
