Search In
  • More options...
Find results that contain...
Find results in...
Need input on first Gaming PC
I'm currently located  in the US and plan on building my first gaming PC with a budget of around $2400.
Here is my current part list of items I choose myself.
(https://pcpartpicker.com/user/ohKast/saved/pnnGGX
The input I need and goals of this build is:
  • Should I change any parts for better deals or performance?
  • Can I trust buying used parts such as a GPU and monitor?
  • I plan on gaming at 1080p at high refresh rates and FPS.
  • If you can provide feedback about parts in the current list if you own them and how they perform
  • Any advice, wisdom, or information is appreciated
get a 1440p 144hz monitor instead, do you really need the extra 60hz monitor?
I can't visually see a difference between 144Hz and 240Hz monitor after a month of use, but I don't have good pair of eyes either so there's that.
If this build emphasis on Asus RGB sync and looks overall, I have nothing to add.
Model: HP Omen 17 17-an110ca CPU: i7-8750H (0.125V core & cache, 50mV SA undervolt) GPU: GTX 1060 6GB Mobile (+80/+450, 1650MHz~1750MHz 0.78V~0.85V) RAM: 8+8GB DDR4-2400 18-17-17-39 2T Storage: 1TB HP EX920 PCIe x4 M.2 SSD + 1TB Seagate 7200RPM 2.5" HDD (ST1000LM049-2GH172), 128GB Toshiba PCIe x2 M.2 SSD (KBG30ZMV128G) gone cooking externally Monitor: 1080p 126Hz IPS G-sync
Desktop benching:
You should have optane to speed your hard drive
CPU: Intel - Core i7-8700K 3.7GHz 6-Core Processor  ($379.99 @ Amazon)
CPU Cooler: EVGA - CLC 280 113.5 CFM Liquid CPU Cooler  ($102.79 @ Amazon)
Motherboard: MSI - Z370 GAMING PRO CARBON ATX LGA1151 Motherboard  ($169.99 @ B&H)
Memory: G.Skill - Trident Z RGB 16GB (2 x 8GB) DDR4-3000 Memory  ($154.99 @ Newegg)
Storage: ADATA - XPG SX6000 256GB M.2-2280 Solid State Drive  ($54.99 @ Amazon)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($58.89 @ OutletPC)
Video Card: MSI - GeForce GTX 1080 Ti 11GB GAMING Video Card  ($699.99 @ Newegg)
Case: Corsair - Carbide Series 275R (White w/Tempered Glass) ATX Mid Tower Case  ($79.99 @ Amazon)
Power Supply: Corsair - RMx (2018) 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($99.99 @ Amazon)
Monitor: Asus - VS229H-P 21.5" 1920x1080 Monitor  ($83.80 @ Amazon)
Monitor: Acer - Predator XB241YU 23.8" 2560x1440 165Hz Monitor  ($399.99 @ Newegg Business)
Keyboard: Corsair - STRAFE RGB Wired Gaming Keyboard  ($89.99 @ Amazon)
Mouse: Corsair - M65 PRO RGB FPS (White) Wired Optical Mouse  ($52.99 @ Amazon)
Other: Phanteks RGB LED 4 Pin Adapter, Specified for Phanteks Cases with RGB  ($2.83 @ Amazon)
Other: Phanteks PH-FF120RGBP Halos RGB Fan Frame – High density LEDs, RGB,  ($10.38 @ Amazon)
Other: Phanteks PH-FF140RGBP Halos RGB Fan Frame – High density LEDs, RGB,  ($10.45 @ Newegg)
Total: $2472.87
Generated by PCPartPicker 2018-10-08 06:14 EDT-0400
PCPartPicker part list: https://pcpartpicker.com/list/3wnDhy
Price breakdown by merchant: https://pcpartpicker.com/list/3wnDhy/by_merchant/
CPU Cooler: Corsair - H100i v2 70.7 CFM Liquid CPU Cooler  ($100.99 @ Amazon)
Storage: Samsung - 860 Evo 500GB 2.5" Solid State Drive  ($87.99 @ Amazon)
Storage: Seagate - BarraCuda 4TB 3.5" 5400RPM Internal Hard Drive  ($97.99 @ OutletPC)
Case: Lian-Li - LANCOOL ONE DIGITAL ATX Mid Tower Case  ($88.99 @ SuperBiiz)
Case Fan: Thermaltake - Riing 14 RGB 3-Pack 51.1 CFM  140mm Fans  ($54.88 @ OutletPC)
Monitor: AOC - AG271QX 27.0" 2560x1440 144Hz Monitor  ($372.99 @ B&H)
Keyboard: Corsair - K65 RGB Wired Gaming Keyboard  ($94.94 @ Amazon)
Total: $2456.71
Generated by PCPartPicker 2018-10-08 06:40 EDT-0400
Total: $2456.71
The PCPartPicker link you sent doesn't work cab you resend it with the shareable link please.
and now?
42 minutes ago, LukeSavenije said:
and now?
Yes thank you.
Build this instead...
CPU Cooler: be quiet! - Dark Rock Pro 4 50.5 CFM CPU Cooler  ($84.99 @ SuperBiiz)
Motherboard: Gigabyte - Z370 AORUS GAMING WIFI (rev. 1.0) ATX LGA1151 Motherboard  ($133.88 @ OutletPC)
Memory: G.Skill - Ripjaws V 16GB (2 x 8GB) DDR4-3000 Memory  ($123.99 @ Newegg)
Storage: ADATA - Ultimate SU650 480GB 2.5" Solid State Drive  ($66.99 @ Newegg)
Video Card: Zotac - GeForce GTX 1080 Ti 11GB AMP Edition Video Card  ($689.99 @ SuperBiiz)
Case: NZXT - H500 (White) ATX Mid Tower Case  ($69.99 @ B&H)
Power Supply: Corsair - RMx (2018) 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($74.99 @ Newegg)
Case Fan: Thermaltake - Riing 12 RGB 48.8 CFM  120mm Fans  ($57.99 @ OutletPC)
Monitor: HP - 22cwa 21.5" 1920x1080 60Hz Monitor  ($89.99 @ Amazon)
Mouse: Logitech - G502 Proteus Spectrum Wired Optical Mouse  ($49.97 @ Amazon)
Total: $2371.63
Generated by PCPartPicker 2018-10-08 16:49 EDT-0400
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
 Share
